tobiasrubin
Dec 05, 2022Aspirant
Unable to log into CAX80 it reverts back to PwdRec
When I try to access the CAX80 at 192.168.1.1 it reverts back to 192.168.1.1/PwdRec_index.htm. The only way I can get rid of this is to reboot, but that becomes annoying over time. Any help would b...
Dec 08, 2022Guru - Experienced User
I use two upper case letters, 5 lower case letters and 3 numbers. I've not seen any issues thus far with this kind of PW config on v21.5.2. The only time I did was when the browser kept using a old save PW profile that I though was correct and once I cleared this profile, the issue hasn't re-appeared.
ThomasDW
Mar 15, 2023Aspirant
Have you ever found solution to this? I am also having this issue. Resetting my cable modem every time this happens is not an option. My password has all the marks Upper, Lower, Number, and Special (hyphen).
- FURRYe38Mar 16, 2023Guru - Experienced User
I don't use special characters, only Upper, Lower and numbers.
Be sure to clear out all browser caches and remove any saved PW profiles for the modem from the browser, then re-install the PW profile.
I use MS-Edge.
