sk17
Oct 01, 2019Initiate
Unable to login and reset NETGEAR47 router admin password, in return not able to reset WIFI password
Hi, i've recently got comcast connection setup. Now, when I tried to reset password for wifi, I'm facing issues: 1. Not able to login on routerlogin.net with admin password. 2. after few att...
Oct 01, 2019Guru - Experienced User
Please confirm what NG product you have. Your tag line says a CM500 which this is a modem only with out built in router nor Wifi.
Do you have a external router connected to this modem?
sk17 wrote:Hi,
2. after few attempts, it asks me to reset admin account, that again asks for security questions which I haven't set
3. I tried setting up wifi password through the steps provided on the Netgear portal.
http://www.loginrouterlogin.net/router-login/
4. Restart of computer and router/modem didn't help either.
Can anyone please help on this.
Thanks,
SK
sk17
Oct 09, 2019Initiate
Hi,
I'm using "N600 WiFi Cable Modem Router", Model - C3700v2.
I tried again but still I'm unable to set the password.
Thanks.
- FURRYe38Oct 10, 2019Guru - Experienced User
Factory reset the modem and with a wired PC and web browser walk thru the wet up wizard.
You can also set a different SSID name as well. You don't have to use NETGEAR47.
sk17 wrote:Hi,
Thanks.
