sk17
Oct 01, 2019Initiate
Unable to login and reset NETGEAR47 router admin password, in return not able to reset WIFI password
Hi, i've recently got comcast connection setup. Now, when I tried to reset password for wifi, I'm facing issues: 1. Not able to login on routerlogin.net with admin password. 2. after few att...
sk17
Oct 09, 2019Initiate
Hi,
I'm using "N600 WiFi Cable Modem Router", Model - C3700v2.
I tried again but still I'm unable to set the password.
Thanks.
Oct 10, 2019Guru - Experienced User
Factory reset the modem and with a wired PC and web browser walk thru the wet up wizard.
You can also set a different SSID name as well. You don't have to use NETGEAR47.
sk17 wrote:Hi,
Thanks.
