krisjans
Mar 15, 2023Aspirant
Unable to login to C6300 router
Hi, I am trying to login to my router, on the device it says access routerlogin.net but that doesn't work. I am being navigated to NETGEAR website and there is no help there. I tried 192.168.0....
krisjans
Mar 16, 2023Aspirant
Thanks for your response, I am using windows.
I have tried multiple browsers in incognito mode. Was not able to connect in any case.
Thanks,
Kris
Thanks,
Kris
Kitsap
Mar 16, 2023Master
Thanks,
Kris
With your Windows 10 computer connected to the router, go to Windows settings -> network and internet -> status -> view hardware and connection properties. In the window it will give your an IPv4 address for the Default Gateway. That is the IP address of your router. Something like 192.168.??.?? or 10.0.?.?. It is an IPv4 address and that is what you should put in the address bar of your web browser to access the user interface. Maybe try in in normal mode, incognito does not do anything for you when trying to connect to a web address on your own network.
Recommend you bookmark the address.
