toltrider
Apr 16, 2019Aspirant
unable to re-connect wireless AC1750cable modem router to Canon Pixma MG7720
My wireless cable modem router worked without issues when my iMac and Canon Pixma 7720 were connected wirelessly. I had to print something from my HP laptop so i connected the laptop and printer by ...
- Apr 16, 2019
Have you rebooted the modem then attempted to install and connect the printer wirelessly?
Sounds like something happend on the Mac. When you had the Mac and printer connected wirelessly OSX makes one printer setup for it in the Preferences. If you connected the USB cable from the Mac to the printer, then this would create another printer selection in the OSX Preferences for this connection. So you would have had two connections for the printer. You may have selected the wrong printer after you disconnected the USB cable.
You'll need to ensure the printer driver is removed from the mac and then follow the printers setup process to get it wirelessly connected. You'll need to refer to the printers Mfrs support site and pages. You may want to phone them to get help if you can't get it installed again.
Apr 16, 2019Guru - Experienced User
- toltriderApr 17, 2019Aspirant
Thank you. Your directions did allow me to get the printer to operate wirelessly. I uninstalled then reinstalled the printer.
I still can't access the router settings. Should I care?
OK with router access. I restarted the modem router and was able to get into router. Thanks again for your help.
- FURRYe38Apr 17, 2019Guru - Experienced User
Enjoy. :smileywink:
