lvshankar
Jan 05, 2022Aspirant
Unable to reset router password on CAX80
(For some reason I'm unable to enter the model number in the given field) I have a NETGEAR - Nighthawk Dual-Band AX6000 Wi-Fi 6 Router with 32 x 8 DOCIS 3.1 Cable Modem that I've been using without ...
- Jan 27, 2022
Circling back with an update on this.
I had a Netgear Nighthawk R6700 that was also hooked to the CAX80. Weirdly, despite the web interface showing CAX80, the password was being set on the Nighthawk instead. I had to reset the CAX80 for other reasons so I'll mark this the solution and give kudos where appropriate. Thanks, all !
lvshankar
Isn’t that just a hard reset? I wanted to avoid doing that if possible
Jan 06, 2022Guru - Experienced User
The reset needs to be done so you can walk thru the setup wizard and input corrected PW and security information. Please write this information down for safe keeping.
- lvshankarJan 06, 2022Aspirant
ok, maybe there's some misunderstanding here. I'm supremely confident I'm entering the correct password. I tried all the tricks in the book like copy paste and password generator
