RamRod123
Dec 03, 2017Follower
Unable to set up MOCA decives with my CM600 modem and Nighthawk router
I just installed both of these to replace my old comcast modem/router combo. Before i bought this i was told that it was MoCa enabled and compatable with my device. I just wanted to know what I am do...
TheEther
Dec 03, 2017Guru
The CM600 is a DOCSIS modem. It doesn't support MoCA. MoCA can coexist with DOCSIS on the same coax cable, but you will need a second MoCA adapter. Here is one way to set up things:
[coax from street]+--+[PoE filter]+--+[splitter]+--+[CM600+--+[R7000]
[ActionTec]+-----+ +------------+[MoCA Adapter]
Alternatively:
[ActionTec]+----------------------+[MoCA Adapter]
- vkdeltaDec 04, 2017NETGEAR Employee Retired
did you buy right kind of splitter? for MoCA splitters need to support upto 2GHz (standard splitters have cutoff at 1 GHz).
Btw, Nice ASCII Art typing. Do you do it by hand or you have a tool to do it?
- TheEtherDec 04, 2017GuruI just Googled for 'ascii art tool' and used the first hit: asciiflow.com. It has the basic tools for drawing.
