Jammas
Sep 20, 2018Aspirant
Unidentified network, no Ethernet or wireless connection
I recently moved into a new apartment, and this router has been with me for a few years. Yesterday out of nowhere it stopped working. I’ve tried restarting the router and modem. When I connect an Ethe...
lorein0688
Sep 24, 2018Aspirant
Check the cables are plugged properly or first plug out entire cables and the re-plug them and check if this works for you. Apart from that Change your DNS Servers and check if this works or try to manually add the ID address.
Hope this works but if not then read the article to follow more detailed steps and solutions: https://www.fixwindowserrors.biz/blog/resolve-unidentified-network-error-on-windows-10
