JamesWino
Sep 12, 2018Aspirant
UniFi USG with CM1000
I have a CM1000 and the WAN is connected to a SRX3205 VPN gateway. I have no issues and when I connected these, everything worked immediately. The only problem is the WAN to LAN performance on the ...
- Sep 12, 2018
CM1000 is a BRIDGE modem. It has passes on DHCP transactions from ISP directly to device on the LAN side. no config is needed.
192.168.100.1 is the DAIGNOSTIC IP for checking GUI and logs.
you should set the USGUniFI to DHCP and it should automatically get DHCPv4 and DHCPv6 from ISP directly.
vkdelta
Sep 12, 2018NETGEAR Employee Retired
JamesWino
Sep 13, 2018Aspirant
Thanks VKDelta! You nailed it and I had some bad info from the tech folks at UniFi but they do not understand the CM1000.
Best,
JW
- vkdeltaSep 13, 2018NETGEAR Employee Retired
thanks! Glad it worked.
Please feel free to leave a amazon Review :)
https://www.amazon.com/NETGEAR-Gigabit-Compatible-Gig-Speed-CM1000-1AZNAS/
https://www.amazon.com/NETGEAR-Gigabit-download-Compatible-Gig-Speed/dp/B01I5TJGSE/
