Sklldr
Nov 11, 2024Aspirant
Unknown Wired device
I've seen other similar posts, but mine is different in several aspects. Had Comcast come out as my desktop hard-wired to the router was getting speeds of only 150Mbps where my plan was up to 800. Af...
Nov 11, 2024Guru - Experienced User
https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-modem-router
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Does it give a IP address of this device?
Does anything for this device appear on the CAX web page under connected devices?
What happens if you disable Armor temporarily on the NH app and reboot the CAX30?
Sklldr
Hi there, here are my responses:
- Firmware ver 2.2.2.2
- Wired device had an IP of 192.168.1.10, MAC traced back to Taiwan as a Hitron router
From access control:
After I blocked it, it doesn't show up as a connected device for me on the NIghthawk App anymore.
Event log:
I'm gonna hold off on restarting my router b/c my issue was that my speed was throttling down from 600 to 100Mbps, sometimes after only a few minutes of restarting my router. So, the Comcast guy just came and updated my coax and removed the filter so i want to leave it alone to monitor to see if it drops again. But can do it tonight if it holds. Thanks!
- FURRYe38Nov 11, 2024Guru - Experienced User
Please post a copy and paste of the modems connection status log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-routerAny Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
- SklldrNov 11, 2024Aspirant
Here you go:
The interesting thing to note was that, prior to the tech coming out, I've never had any random unknown wired connections. That said, my cable connection always was listed as "Good". So, the speed issues i've been encountering existed regardless of what the cable connection status was.
We need the information that is displayed farther down that page please.
