softciy
Feb 22, 2020Aspirant
unlocked channels means?
cm-1000 Netgear modem What is causing these? Is this a normal profile, anything out of th ordinary?
Feb 22, 2020Guru - Experienced User
Some isp's setup would leave channel 32 unlocked and lock in the ofdma channel.
Are your speeds ok?
Your signal doesn't look to bad but look like a few channels might have a little interference. Nothing thats horrible but you could always check your splitters/cable/connections to optimize.
- softciyFeb 23, 2020Aspirant
Thanks for the reply.
Speeds are excellent. 200Mbits down, 7Mb up (pretty close to what we pay for)
What about the unlocked Upstream? There is 4 unlocked, shouldnt that be all unlocked UP?
- plemansFeb 23, 2020Guru - Experienced User
upstream is your upload. its standard for 3-4 to be locked to hit upstream speeds.
- softciy2001Feb 23, 2020Aspirant
I meant shouldnt they ALL be LOCKED upstream?
Currently 4 of the 8 are locked.
Also , isnt the netgear cm-1000 supposed to be 32 down and 16 up??
plemans wrote:upstream is your upload. its standard for 3-4 to be locked to hit upstream speeds.
