g4b1t0
May 19, 2022Follower
Unmanaged GS308 + Nighthawk CM2050V
Hello, hoping someone can help me figure out the following: I have a CM2050V that I am now using and is replacing a Xfinity modem, xfinity was able to make the transition without problems. fr...
May 19, 2022Guru - Experienced User
To make that work right, you need a external wifi router in between the CM modem and GS series switch. The CM series modem is a modem only. Does NOT have a built in router.
