Karaptian
Mar 10, 2021Aspirant
Unregister Modem
When I originally purchased my CM500 modem, I registed it with Netgear. The product is no longer under warranty and I don't use it. I gave the modem to a family member. They tried to use it w...
Mar 10, 2021Guru - Experienced User
You would need to contact the prior ISP where that modem was used and have them remove it from there system.
