ihlejohn
Mar 28, 2019Aspirant
Unstable download speeds using CM1000 modem with Xfinity
This morning my internet was working fine. Normally i have my cm1000 modem connected to my nighthawk x4s router and that router connects to my computer using an ethernet cable. I unplugged my compute...
Mar 28, 2019Guru - Experienced User
Sounds like you've done half the battle isolating it to the modem. Great work! Since it was working fine before just a couple questions.
A what speeds do you pay for?
do you have a screen shot of your modem connection page? these give us a brief overview of powerlevels etc. Keep in mind, they're only a snapshot of when you pull up the page.
And screenshot of your modem logs?
Have you checked your connections and cables? And not just from the wall to the modem but ALL of the connections/cables from where it (xfinity) enters the house? A sketchy cable or connection can cause interference and problems.
Did anything change when you were reinstalling? And by this I mean, remove coax splitters from line, change to a different coax.
Thanks!
- ihlejohnMar 28, 2019AspirantSorry it took a while I was having trouble uploading due to this issue so I had to take pictures with my phone and upload, hopefully they’re legible.
https://imgur.com/gallery/JhhxZzG
As far as I can tell the cable entering the house is the same as it was before but I can’t be sure. I’m using the same coax and it is tightened securely. Nothing has changed besides only using the modem at the moment. The problem feels worse than when I originally posted and there were obviously an increase in uncorrectable codewords.
After trying to upload those images channel 31 (channel ID 33) had 3824 uncorrectable codewords and 3609 correctable. But I’m not going to try to get another screenshot of that haha. And the ofdm channel increased to 203 uncorrectable.- ihlejohnMar 28, 2019AspirantForgot to mention I pay for 150 Down and it regularly tests at 200.
- plemansMar 28, 2019Guru - Experienced UserI've also seen cables get jammed back into boxes and get kinked, which can cause issues. Something to check
- plemansMar 28, 2019Guru - Experienced UserDoes the coax enter from a wall plate? Did you open it when you painted? I'd specifically check there as well as replace the cable from the plate to the modem if you have a spare.
