Mechtech57
Jan 12, 2023Aspirant
Unstable internet connection when using Zoom
Hello. When I am on a Zoom call the video and audio freezes for about 15 seconds and then resumes. This happens about every ten minutes or so. I was using an older laptop and thought it might be havi...
Jan 12, 2023Guru - Experienced User
How is Basic and Advanced wireless settings configured on the modem?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Enable Beamforming and MIMO. Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 64. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Mechtech57
Jan 13, 2023Aspirant
I was able to find some of your suggestions.
My firmware version is V1.4.11.2
There is a lot of info available under Basic and Advanced wireless settings. Can you be more specific?
Beam forming and MIMO are already enabled.
Traffic meter is already disabled.
I cannot find Armor, Smart Parental Controls or Circle.
I cannot find 20/40Mhz Coexistence to 40Mhz only.
Is CTS the same as CTS/RTS Threshold and do I change it for both 2.4 and 5 Ghz?
I set to short preamble.
I changed channels from Auto to channel 1, on 2.4Ghz. I left 5Ghz at the preset because it was recommended by Netgear.
- FURRYe38Jan 13, 2023Guru - Experienced User
What channels is the modem set for?
Try setting manual channel 40 to 48 channel on 5Ghz if needed.
Is WMM enabled under advanced wireless settings?
Uncheck the check box next to 20/40Mhz Coexistence and apply the setting.
CTS should be defaulted to 2347, leave this if it's at this value for both radios.
Might disable Traffic Meter temporarily.
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200. Under Advanced Tab/Setup/LAN Setup.
- Mechtech57Jan 20, 2023Aspirant
Is there anybody out there that can help me with this problem? I need someone that can be more specific with instructions. Thank you.
- FURRYe38Jan 20, 2023Guru - Experienced User
Log into the modems web page at 192.168.1.1 using a web browser.
If you need help on this, you might find a friend or neighbor to help you with this on site...
