Mechtech57
Jan 12, 2023Aspirant
Unstable internet connection when using Zoom
Hello. When I am on a Zoom call the video and audio freezes for about 15 seconds and then resumes. This happens about every ten minutes or so. I was using an older laptop and thought it might be havi...
Mechtech57
Jan 13, 2023Aspirant
I was able to find some of your suggestions.
My firmware version is V1.4.11.2
There is a lot of info available under Basic and Advanced wireless settings. Can you be more specific?
Beam forming and MIMO are already enabled.
Traffic meter is already disabled.
I cannot find Armor, Smart Parental Controls or Circle.
I cannot find 20/40Mhz Coexistence to 40Mhz only.
Is CTS the same as CTS/RTS Threshold and do I change it for both 2.4 and 5 Ghz?
I set to short preamble.
I changed channels from Auto to channel 1, on 2.4Ghz. I left 5Ghz at the preset because it was recommended by Netgear.
Jan 13, 2023Guru - Experienced User
What channels is the modem set for?
Try setting manual channel 40 to 48 channel on 5Ghz if needed.
Is WMM enabled under advanced wireless settings?
Uncheck the check box next to 20/40Mhz Coexistence and apply the setting.
CTS should be defaulted to 2347, leave this if it's at this value for both radios.
Might disable Traffic Meter temporarily.
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200. Under Advanced Tab/Setup/LAN Setup.
