Rysterdown
Jan 27, 2021Aspirant
Unstable Internet Connection
I bought a new router and modem about 3 months ago. I have a R8000P Nighthawk X6S AC4000 Tri Band WiFi Router and a CM 1200 Netgear Modem. My modem receives internet from Cox via wired connection, an...
Rysterdown
Jan 28, 2021Aspirant
That is the only splitter that I know of. Are the splitters potentially the cause of the power fluctuation in the modem? Could there be other possible causes?
Jan 28, 2021Guru - Experienced User
many things can cause it.
damage to the coax
moisture in the line
old/bad/cheap connectors
corrosion
loose connections
but if there's a splitter, try removing it first in case its the issues. Preferably, directly connect the modem to where the coax enters the home and use it for a period. that'll let you check the incoming line. If you still have the issue, then it means its either the line or the modem
