24nocturnal's avatar
24nocturnal
Follower
Nov 18, 2017
update firmare ac1750 cable modem
how do you update your firmware on an ac1750 cable modem.  I tried going through my ISP, however since it is not thier equipment they are unable to update it for me.  And it does not give me an option to update in the routerlogin.net-advance-adminstration options.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    You can not manually update the firmware on any cable modem we send the firmware to the ISP it goes through a certification and then the ISP will push it to your modem automatically even if its a customer owned modem.
    DarrenM
