mtcoleman1
Nov 26, 2015Aspirant
Update Firmware CG3000D
How do I update firmware for a Netgear CG3000D? I need to change my DNS Servers for NBC.
DarrenM
Nov 30, 2015Sr. NETGEAR Moderator
Hello mtcoleman1
The isp does all the updates for firmware so if there is a firmware update all you would have to do is unplug your modem and plug it back in and it will auto update.
DarrenM
mtcoleman1
Nov 30, 2015Aspirant
I purchased my router from Amazon. It was not provided by my ISP. I need to change the primary and secondary DNS servers for NBC programming through my Roku. I saw on the comunity that updating my firmware was required to make DNS changes. Thanks for your help.
- DarrenMNov 30, 2015Sr. NETGEAR Moderator
mtcoleman1
That model does not look like it has the option to change the DNS it will use the one from the isp and even though you bought the modem the isp still controls the firmware but have you tried changing the DNS server in the roku itself?
DarrenM
- mtcoleman1Nov 30, 2015Aspirant
Darren, how that done?
Michael
mtcoleman1
Im not to familiar with roku but there should be a menu for internet setup in it and if you can do a manual ip setup you should be able to input the DNS.
DarrenM
