zunka
Aug 07, 2021Guide
Update Modem Firmware Manually
I am using CM1150v Modem with OPTIMUM (in NJ). Since this is not a modem provided by OPTIMUM they will not push any firmware updates. Netgear KB does not provide any solution. How can I upda...
zunka
Aug 08, 2021Guide
Few minutes ago I did a hard reset on the modem (put paper clip in the Reset buttom at the back of the modem).
This seems to have resolved the problem My speed is back up to 940 Mbps.
The Event logs got cleared as part of the reset. Therefore are not of much value.
I will keep checking the speed over the next day and post the details you asked for if it drops back to 30 Mbps.
Thank you.
Aug 08, 2021Guru - Experienced User
Good luck, hope it was that simple of a fix.
