zunka
Aug 07, 2021Guide
Update Modem Firmware Manually
I am using CM1150v Modem with OPTIMUM (in NJ). Since this is not a modem provided by OPTIMUM they will not push any firmware updates. Netgear KB does not provide any solution. How can I upda...
Aug 08, 2021Guru - Experienced User
Good luck, hope it was that simple of a fix.
zunka
Sep 18, 2021Guide
Unfortunately after little over a month, my speed has unexpected dropped to 30 Mbps. Last time a hard reset solved the problem but want to know what is causing it.
I have attached the Cable Connection and Event Lot. Can you help figure out the root cause?
Again, I have not made any changes to my setup nor installed any new software.
Thank you in advance.
