zunka
Aug 07, 2021Guide
Update Modem Firmware Manually
I am using CM1150v Modem with OPTIMUM (in NJ). Since this is not a modem provided by OPTIMUM they will not push any firmware updates. Netgear KB does not provide any solution. How can I upda...
zunka
Sep 23, 2021Guide
My warranty has expired. It has been slightly over an year since I purchased. Let me try the option you suggested. Hopefully if the technician brings a modem with him/her that we could try out, there may not even be a need to rent.
Thank you.
Sep 23, 2021Guru - Experienced User
Good luck!
