donawalt
Mar 02, 2024Mentor - Experienced User
Update on CM2050V firmware?
Hi, is there any update to the CM2050V firmware that will re-enable the mid-split higher upload speeds? The latest firmware was pulled in October maybe? Any update to this thread's status reporting? ...
- Mar 02, 2024
Nothing yet. We don't get that info from NG.
Mar 14, 2024Guru - Experienced User
The CM2050V is being worked on is all I can say.
How's your CM3000 doing? Been enjoying mine. đ
- donawaltMar 14, 2024Mentor - Experienced User
It's working good! It's been up just about 1 day now. The web interface is identical to the CM2000 and CM2050 as far as data reported. Power levels and SNR consistent with those models. no correctible or uncorrectable errors yet, so no issues on the mid-split network so far. I got one T3 error yesterday, I only noticed it through the log though. Speeds are great.
- FURRYe38Mar 14, 2024Guru - Experienced User
Good to hear.
There a speed test capture you could post? - donawaltMar 14, 2024Mentor - Experienced User
speeds are great - here's a sample:
One thing I have not seen at my home before, I regularly get pings of 5ms, 8ms - I have never gotten single digits that I can recall. Not every time, but still...
Actually they are not from the modem, the router runs Ookla Speediest on it - I ran it through their Orbi ap.
Here were the first two WiFi runs I did, you can see upload went from 40 to 237. It's an iPhone 15 (Wifi 6e) and the RBR 960 (also WiFi 6e), that will matter of course.
