winchester30
Oct 07, 2019Aspirant
Upgrade recommendation
WNDR4500v2 N900 Router is 7 years old, time for much needed upgrade! Needs: Good range, large 2 story house with router located in basement. Devices: 2 internet streaming tv's, Xbox, multiple iph...
Oct 07, 2019Guru - Experienced User
https://www.netgear.com/home/products/networking/wifi-routers/
Check out what routers may fit your needs.
winchester30
I already have visited that web page, after checking the appropriate boxes it still leaves me with 20+ choices...
- FURRYe38Oct 08, 2019Guru - Experienced User
I would find something that best suites your needs, devices and has some room for future growth.
winchester30 wrote:I already have visited that web page, after checking the appropriate boxes it still leaves me with 20+ choices...
- winchester30Oct 08, 2019Aspirant
Thanks?
I will see if Best Buy or OfficeMax is more helpful.
Hard to make some suggestions since users needs and use differ. Why there is wide range of routers available for users needs. Kind of up to users to find what best suites there needs.
Take in to account house size, building materials and surroundinds will effect wifi coverage and performances.
Take in to account what devices you have and what you do with them as well. Types of uses are gernal internet useage, gaming, video streaming, camera operations and new IoT devcies like Echo Dot and such.
Lots of considerations and factors to think about to decide what kind of router system you want and need.
