Chance45
May 31, 2020Aspirant
Upgrade to CM1200 from cm1000
Just wondering if anyone has upgraded their cm1000 to cm1200 modem. I recently made the switch but it's looking like cm1000 is more consistent and faster than the cm1200.
May 31, 2020Guru - Experienced User
If you're using the cm1200 with link aggregation enabled, disable it.
- Chance45May 31, 2020Aspirant
Its actually currently on disable. Should I try it with Enable (LACP-IEEE 802.3ad) (Port 1 & 2) on?
- plemansMay 31, 2020Guru - Experienced User
no. its fine.
The cm1200 and the cm1000 use basically the same chip. So there really shouldn't be a difference in performance unless you're using the wan aggregation.
Do you have a screen snip of the cable connections page from it?
These are the screenshots I have. Let me know if you think I should make adjustments.
