Chance45
May 31, 2020Aspirant
Upgrade to CM1200 from cm1000
Just wondering if anyone has upgraded their cm1000 to cm1200 modem. I recently made the switch but it's looking like cm1000 is more consistent and faster than the cm1200.
May 31, 2020Guru - Experienced User
Your power levels are all over the place. Ideally for downstream you want -7 to +7 dbmv. you're seeing -16.3dbmv at one point. and they should be within roughly 3.5dbmv of each other. yours has roughly 7dbmv range. so your downstream isn't decent.
your upstream is coming in high. high enough to cause drops.
I'd check your line by removing any splitters, attenuators, amplifiers from the line. directly connect to where the coax comes in.
If that's all already done, then your isp needs to check the line.
Chance45
Thanks for the insight. I'm going to have to wait to update you on this. I'll call Comcast once quarantine is lifted in CA.
