maxxum23
Feb 02, 2024Aspirant
Upgraded from CM600 to CM1200, upload speed halved
I figured I'd ask here before I return the new modem. I have an xfinity 400mbps down/100mbps upload speed plan. I had been using the CM600 for a while, which gave a good 450mbps/12mbps down/up. Xfin...
Feb 03, 2024Guru - Experienced User
I'd return it and get either a coda56 or wait and get the CM3000 when its released. those will both support xfinity's "next gen" speeds and you'll get the faster 100mbps upload. The CM1200 isn't currently on that list and I haven't heard anything about it being worked on yet.
- plemansFeb 03, 2024Guru - Experienced User
Their list of supported devices for next gen speeds can be found here:
knowledgebase/next-generation-internet - Comcast_Xfinity (reddit.com)
Plus I think the coda56 is cheaper.
- maxxum23Feb 03, 2024AspirantYes. This one is going right back.
FWIW I connected a laptop directly using a cable to the modem and tested it. The upload is still under 6mbps.- maxxum23Feb 05, 2024Aspirant
Back to the old modem CM6900 (docsis 3.0). Unfortunately the old upload speed of 12mbps was no longer available, and now this one also gets only 6mbps. It has to do with Xfinity but they will charge for every visit they make, because I am not renting equipment from them. Perhaps a change in provider is in order.
- FURRYe38Feb 05, 2024Guru - Experienced User
IF you have that option, something to explore.
