maxxum23
Feb 02, 2024Aspirant
Upgraded from CM600 to CM1200, upload speed halved
I figured I'd ask here before I return the new modem. I have an xfinity 400mbps down/100mbps upload speed plan. I had been using the CM600 for a while, which gave a good 450mbps/12mbps down/up. Xfin...
maxxum23
Feb 03, 2024Aspirant
Yes. This one is going right back.
FWIW I connected a laptop directly using a cable to the modem and tested it. The upload is still under 6mbps.
maxxum23
Feb 05, 2024Aspirant
Back to the old modem CM6900 (docsis 3.0). Unfortunately the old upload speed of 12mbps was no longer available, and now this one also gets only 6mbps. It has to do with Xfinity but they will charge for every visit they make, because I am not renting equipment from them. Perhaps a change in provider is in order.
- FURRYe38Feb 05, 2024Guru - Experienced User
IF you have that option, something to explore.
- KitsapFeb 05, 2024Master
Additional information on Xfinity with the CODA and CODA56 modems can be found here:
https://www.dslreports.com/forum/r33821305-Equip-Xfinity-customers-with-CODA-CODA56-modems
