jpollo02
Aug 20, 2020Aspirant
upgrading CM500 firmware if ISP won't do it?
I have a Netgear CM500 modem. After logging into it, I discovered it's on V1.01.04 but it should be at V1.01.12. I spoke to my ISP (it's called WOW!) and they said that because it's my modem, they ...
Aug 20, 2020Guru - Experienced User
IF your with and ISP that doesn't update FW for user owned modems, then unfortunately you are stuck. Cable ISPs handle FW updates for cable modems user owned or other wise. Some will some will not.
Is there a problem with the modem? If not, then there isn't any reason to update if the modem is working.
