leehop71
Apr 02, 2019Aspirant
Upgrading from 16/4 Channels to 24/8 Channels
Greetings! Newbie here.
I have a Netgear C6300 modem router combo.
I am in the process of adding Ring Security doorbell, cameras, and lighting around my house, in addition to the devices I alre...
Apr 02, 2019Guru - Experienced User
The C6300 is rated for 680 mbps download optimally. That means signals, channels, your coax, your line, etc are all perfect. You don't say what you're paying for or if you currently get the speed you pay for. That the biggest question. If its working and you're getting the speeds you pay for, upgrading isn't going to help unless you're trying for better wifi coverage. But that'd be a different conversation.
For a while I was running around 40 wireless devices and 20 wired devices over a 100 mbps connection (now gigabit for my own satisfaction). Everything ran fine. So its about making sure you get the speeds you're paying for and your wireless layout adequately covers the area. I'd try the new setup and see how it works and if something else needs optimizing before jumping to a new modem.
Hope this helps a little.
leehop71
Apr 06, 2019Aspirant
Thanks for the reply. Actually I have Ring devices and was coming across some issues that support suggestions did not solve. I decided to do away with the combo since consensus was that separate modem was much more stable.
I sold the combo and upgraded to a CM7000 32/8 channels and a R6350. The Ring devices are working flawless now. My home is small 1556sq ft, but my router is at the front of the house where the Comcast cable is.
I'm waiting on Ring devices for the back of the house, thinking the wifi should reach there without issue.
