pinkstonms
Aug 21, 2023Tutor
upgrading from C7000 to mesh system
looking to move up to a mesh system form my home. I plugged in my needs on the filter options and got "Not currently available to purchase on NETGEAR.com" response.
My home is 3700 sq ft. I hav...
Aug 21, 2023Guru - Experienced User
Review something from the following:
https://www.netgear.com/home/wifi/mesh/
Select home size as well to help you narrow it down. I would recommend no more than two satellites for that size of home.
https://www.netgear.com/home/wifi/mesh/listing-filter/upto-5000-sq-ft/
- pinkstonmsAug 21, 2023Tutor
My home is one level and I have easy access to attic to run a wired system any thoughts?
- FURRYe38Aug 21, 2023Guru - Experienced User
Wire can be used and deployed in the attic. Though attic not recommended for actual equipment. Gets hot up there.
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡
https://kb.netgear.com/000061710/What-is-an-Ethernet-backhaul-connection-and-how-do-I-set-it-up-on-my-Nighthawk-Mesh-WiFi-6-productsOnce can use the C7000 as a modem only and connect up any Orbi or Nighthawk MK MESH system to it.
One level then the router and one satellite should be a good start.
