RajaDaja
Feb 26, 2025Luminary
Upload indicator iight very dim
Provider is Xfinity, speed tier is 2 gigs down, 300 mb up. I’m getting these speeds, All the indicator icons on the modem are nice and bright except the upload indicator light. I remember it being lum...
- Feb 27, 2025
If you're not having any issues, I wouldn't worry about it. Most people rarely see them anyway as the modem should be pretty set and forget.
RajaDaja
CM3000
Feb 26, 2025Guru - Experienced User
Have you powered OFF the modem for 1 minute then back ON?
Seen other posts about the CM2000 having similar issues. No issues with the ISP service.
- RajaDajaFeb 26, 2025LuminaryNo, I only did a factory reset which didn’t solve the issue. I’ll try that and see what happens. Thanks
