iceman431970
May 24, 2016Aspirant
Upload light is a solid red. Download is a solid green. LAN is flashing. Speed tests show over 75Mbp
i got a netgear cm500 to replace isp providers modem,called them had them do their thing and activate it,all lights green except upstream is solid red,since i waited 6 months before i hooked this thi...
netwrks
May 24, 2016Master
Did you look at the manual? http://www.downloads.netgear.com/files/GDC/CM500/CM500_UM_Comcast_TWC_19May2015.pdf - Page 6.
iceman431970
yes i had looked in there and saw that it shows all green,but is that the way its supposed to be,or is one actually supposed to be red,it does not give enough information.and if one is supposed to be red,then why is my internet act so sluggish,but the netgear modem says it is working fine.it didnt act like this with the modem rented from isp provider.
