iceman431970
May 24, 2016Aspirant
Upload light is a solid red. Download is a solid green. LAN is flashing. Speed tests show over 75Mbp
i got a netgear cm500 to replace isp providers modem,called them had them do their thing and activate it,all lights green except upstream is solid red,since i waited 6 months before i hooked this thi...
netwrks
May 24, 2016Master
Did you look at the manual? http://www.downloads.netgear.com/files/GDC/CM500/CM500_UM_Comcast_TWC_19May2015.pdf - Page 6.
iceman431970
also i figured out how to get to the logfile in modem and this is what i get to see,not sure why some of it shows yesterdays date and some is for 1-1-1970,none of this makes sense,and im not a computer guru,i just want this to work like its supposed to.
| Time | Priority | Description |
| 1970-1-1, 00:00:47 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:3d:1a:48;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:38 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:3d:1a:48;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:39 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:3d:1a:48;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:46 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:3d:1a:48;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:46 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:3d:1a:48;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:48 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:3d:1a:48;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:48 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:3d:1a:48;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:55 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=40:5d:82:3d:1a:48;CMTS-MAC=00:01:5c:7e:48:5b;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:01:02 | Critical (3) | DHCP FAILED - Discover sent, no offer received;CM-MAC=40:5d:82:3d:1a:48;CMTS-MAC=00:01:5c:7e:48:5b;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:20 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:3d:1a:48;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:31 | Critical (3) | DHCP FAILED - Discover sent, no offer received;CM-MAC=40:5d:82:3d:1a:48;CMTS-MAC=00:01:5c:7e:48:5b;CM-QOS=1.0;CM-VER=3.0; |
| 2016-4-29, 10:29:22 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
| 2016-4-29, 10:30:14 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=40:5d:82:3d:1a:48;CMTS-MAC=00:01:5c:7e:48:5b;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:21 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:3d:1a:48;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:21 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:3d:1a:48;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:29 | Notice (6) | Overriding MDD IP initialization parameters; IP provisioning mode = IPv4 |
| 1970-1-1, 00:00:31 | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=40:5d:82:3d:1a:48;CMTS-MAC=00:01:5c:7e:48:5b;CM-QOS=1.0;CM-VER=3.0; |
| 2016-5-23, 22:10:59 | Error (4) | Missing BP Configuration Setting TLV Type: 17.3;CM-MAC=40:5d:82:3d:1a:48;CMTS-MAC=00:01:5c:7e:48:5b;CM-QOS=1.1;CM-VER=3.0; |
| 2016-5-23, 22:10:59 | Error (4) | Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=40:5d:82:3d:1a:48;CMTS-MAC=00:01:5c:7e:48:5b;CM-QOS=1.1;CM-VER=3.0; |
| 2016-5-23, 22:10:59 | Error (4) | Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=40:5d:82:3d:1a:48;CMTS-MAC=00:01:5c:7e:48:5b;CM-QOS=1.1;CM-VER=3.0; |
