opop
May 04, 2023Aspirant
Uploading remotely to ReadyShare USB on Cax30 router
Hi, I recently left home and I used to upload locally to a USB drive plugged into the back of my CAX30 router to share with my brothers computer. Now that I am in a different city I am tryi...
May 10, 2023Guru - Experienced User
I'd contact Filezilla to be sure that your configuring there application correctly.
Can you access the CAX via FTP in a command line box?
https://www.msnoob.com/ftp-commands-for-windows.html
What do you mean by your in a different city? Are you away from the CAX30 thats at home?
Are you behind a different modem/router in a different city?
opop
May 10, 2023Aspirant
Hi,
I dont know what it was but I reset the password and I was able to get in, maybe it doesn't like $ signs
- FURRYe38May 11, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- opopMay 12, 2023Aspirant
ultimately though the router is still not doing what I need it to do, when uploading large files the connection times out, I can only get about 5mb/second and upload 1 gigabyte. I tried multiple clients.
- FURRYe38May 12, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
