Dbar918
Aug 23, 2023Aspirant
Upstream and downstream locked to one channel each but internet won't connect
My CM1000 has solid amber LED lights for upstream and downstream, but the internet light is blinking green and I do not have a connection. I have verified with my provider multiple times and they told...
Dbar918
Aug 24, 2023Aspirant
Thanks, here is a sample of the log since it's way too long for the post character limit. If the whole thing is needed I can upload it as a file tomorrow.
Also I live in an apartment so I can't access the coax cable other than the wall port, but there are two ports in my unit and they have the same problem.
[admin login] from source 192.168.1.11
[admin login] from source 192.168.1.4
[DHCP IP: 192.168.1.4][Device Name: MSI] to MAC address 38:ba:f8:80:61:4b
[Internet connected] IP address: 192.168.100.10
[DHCP IP: 192.168.1.11][Device Name: ZENFONE-9] to MAC address 06:0a:1f:a0:bf:70
[DHCP IP: 192.168.1.10][Device Name: PETKIT_DFOOD] to MAC address c4:5b:be:c7:16:e5
[DHCP IP: 192.168.1.2][Device Name: XBOX-SYSTEMOS] to MAC address 50:1a:c5:d1:d3:c5
[DHCP IP: 192.168.1.8][Device Name: ] to MAC address b2:8c:c2:7d:2b:1e
Dbar918
While browsing the logs I saw something that seems concerning, but I really don't know much h so maybe it's nothing. Here's a sample:
DoS Attack: RST Scan] from source: 217.117.29.77, port 37873, Friday, August 18, 2023 09:32:36
[DoS Attack: SYN/ACK Scan] from source: 135.125.78.175, port 1237, Friday, August 18, 2023 09:08:56
[DHCP IP: 192.168.1.2][Device Name: XBOX-SYSTEMOS] to MAC address 50:1a:c5:d1:d3:c5, Friday, August 18, 2023 09:07:31
[DoS Attack: RST Scan] from source: 17.248.195.72, port 443, Friday, August 18, 2023 09:06:20
[DoS Attack: SYN/ACK Scan] from source: 162.19.170.45, port 25565, Friday, August 18, 2023 09:03:57
[DoS Attack: ACK Scan] from source: 185.224.128.184, port 29583, Friday, August 18, 2023 08:58:11
[DoS Attack: RST Scan] from source: 17.57.172.11, port 443, Friday, August 18, 2023 08:48:34
[DoS Attack: RST Scan] from source: 17.253.127.202, port 443, Friday, August 18, 2023 08:31:38
[DoS Attack: RST Scan] from source: 17.252.196.22, port 443, Friday, August 18, 2023 08:31:33
[DoS Attack: ACK Scan] from source: 162.254.199.181, port 27033, Friday, August 18, 2023 08:22:57
[DoS Attack: ACK Scan] from source: 155.133.253.50, port 443, Friday, August 18, 2023 08:22:56
[DoS Attack: ACK Scan] from source: 155.133.253.50, port 27034, Friday, August 18, 2023 08:22:56
[DoS Attack: ACK Scan] from source: 162.254.199.181, port 27033, Friday, August 18, 2023 08:22:56
[DoS Attack: ACK Scan] from source: 155.133.253.50, port 27034, Friday, August 18, 2023 08:22:55
[DoS Attack: ACK Scan] from source: 155.133.253.50, port 443, Friday, August 18, 2023 08:22:55
[DoS Attack: ACK Scan] from source: 162.254.199.181, port 27033, Friday, August 18, 2023 08:22:55
[DoS Attack: ACK Scan] from source: 155.133.253.50, port 443, Friday, August 18, 2023 08:22:54
[DoS Attack: ACK Scan] from source: 155.133.253.50, port 27034, Friday, August 18, 2023 08:22:54
[DoS Attack: ACK Scan] from source: 162.254.199.181, port 27033, Friday, August 18, 2023 08:22:54
[DoS Attack: ACK Scan] from source: 162.254.199.181, port 27033, Friday, August 18, 2023 08:22:51
[DoS Attack: ACK Scan] from source: 155.133.253.50, port 27034, Friday, August 18, 2023 08:22:50
[DoS Attack: ACK Scan] from source: 155.133.253.50, port 443, Friday, August 18, 2023 08:22:50
[DoS Attack: ACK Scan] from source: 162.254.199.181, port 27033, Friday, August 18, 2023 08:22:50
[DoS Attack: ACK Scan] from source: 155.133.253.50, port 27034, Friday, August 18, 2023 08:22:49
[DoS Attack: ACK Scan] from source: 155.133.253.50, port 443, Friday, August 18, 2023 08:22:49
[DoS Attack: ACK Scan] from source: 162.254.199.181, port 27033, Friday, August 18, 2023 08:22:49
[DoS Attack: ACK Scan] from source: 155.133.253.50, port 443, Friday, August 18, 2023 08:22:48
[DoS Attack: ACK Scan] from source: 155.133.253.50, port 27034, Friday, August 18, 2023 08:22:48
[DoS Attack: RST Scan] from source: 23.218.232.163, port 443, Friday, August 18, 2023 08:22:36
[DHCP IP: 192.168.1.4][Device Name: MSI] to MAC address 38:ba:f8:80:61:4b, Friday, August 18, 2023 08:21:44
[DHCP IP: 192.168.1.4][Device Name: MSI] to MAC address 38:ba:f8:80:61:4b, Friday, August 18, 2023 08:19:39
[DHCP IP: 192.168.1.4][Device Name: MSI] to MAC address 38:ba:f8:80:61:4b, Friday, August 18, 2023 08:19:14
[DoS Attack: RST Scan] from source: 18.162.43.220, port 80, Friday, August 18, 2023 08:13:39
[DoS Attack: RST Scan] from source: 17.36.206.4, port 443, Friday, August 18, 2023 07:51:30
[DoS Attack: ACK Scan] from source: 194.45.197.222, port 30120, Friday, August 18, 2023 07:43:44
[DoS Attack: SYN/ACK Scan] from source: 162.19.170.45, port 25565, Friday, August 18, 2023 07:29:46
[DoS Attack: SYN/ACK Scan] from source: 135.125.78.175, port 1237, Friday, August 18, 2023 07:24:25
[DoS Attack: RST Scan] from source: 17.57.12.16, port 443, Friday, August 18, 2023 07:21:30
[DoS Attack: SYN/ACK Scan] from source: 162.19.170.56, port 25565, Friday, August 18, 2023 07:17:34
[DoS Attack: SYN/ACK Scan] from source: 193.42.12.170, port 55926, Friday, August 18, 2023 07:10:34
[DoS Attack: RST Scan] from source: 17.57.12.243, port 443, Friday, August 18, 2023 06:47:47
[DoS Attack: RST Scan] from source: 17.253.127.211, port 443, Friday, August 18, 2023 06:47:05
[DoS Attack: ACK Scan] from source: 162.254.199.163, port 27021, Friday, August 18, 2023 06:42:09
[DoS Attack: ACK Scan] from source: 155.133.253.34, port 27036, Friday, August 18, 2023 06:42:09
[DoS Attack: ACK Scan] from source: 162.254.199.163, port 27021, Friday, August 18, 2023 06:42:08
[DoS Attack: ACK Scan] from source: 155.133.253.34, port 27036, Friday, August 18, 2023 06:42:08
[DoS Attack: ACK Scan] from source: 162.254.199.163, port 27021, Friday, August 18, 2023 06:42:07
[DoS Attack: ACK Scan] from source: 155.133.253.34, port 27036, Friday, August 18, 2023 06:42:07
[DoS Attack: ACK Scan] from source: 162.254.199.163, port 27021, Friday, August 18, 2023 06:42:06
[DoS Attack: ACK Scan] from source: 155.133.253.34, port 27036, Friday, August 18, 2023 06:42:06
[DoS Attack: ACK Scan] from source: 162.254.199.163, port 27021, Friday, August 18, 2023 06:42:05
[DoS Attack: ACK Scan] from source: 162.254.199.163, port 27021, Friday, August 18, 2023 06:42:04
[DoS Attack: ACK Scan] from source: 155.133.253.34, port 27036, Friday, August 18, 2023 06:42:04
[DoS Attack: ACK Scan] from source: 162.254.199.163, port 27021, Friday, August 18, 2023 06:42:03
[DoS Attack: ACK Scan] from source: 155.133.253.34, port 27036, Friday, August 18, 2023 06:42:03
[DoS Attack: ACK Scan] from source: 162.254.199.163, port 27021, Friday, August 18, 2023 06:42:02
[DoS Attack: ACK Scan] from source: 155.133.253.34, port 27036, Friday, August 18, 2023 06:42:02
[DoS Attack: ACK Scan] from source: 162.254.199.163, port 27021, Friday, August 18, 2023 06:42:01
[DoS Attack: ACK Scan] from source: 155.133.253.34, port 27036, Friday, August 18, 2023 06:42:01
[DoS Attack: ACK Scan] from source: 162.254.199.163, port 27021, Friday, August 18, 2023 06:42:00
[DoS Attack: ACK Scan] from source: 155.133.253.34, port 27036, Friday, August 18, 2023 06:42:00
[DoS Attack: RST Scan] from source: 17.36.206.5, port 443, Friday, August 18, 2023 06:39:51
[DoS Attack: RST Scan] from source: 52.70.183.252, port 443, Friday, August 18, 2023 06:39:27
[DHCP IP: 192.168.1.4][Device Name: MSI] to MAC address 38:ba:f8:80:61:4b, Friday, August 18, 2023 06:39:11
[DoS Attack: RST Scan] from source: 17.252.196.22, port 443, Friday, August 18, 2023 06:37:53
[DoS Attack: RST Scan] from source: 17.36.206.5, port 443, Friday, August 18, 2023 06:34:11
[DHCP IP: 192.168.1.11][Device Name: ZENFONE-9] to MAC address 06:0a:1f:a0:bf:70, Friday, August 18, 2023 06:23:49
[Internet connected] IP address: 98.172.218.202, Friday, August 18, 2023 06:23:42
[Internet connected] IP address: 192.168.100.10, Friday, August 18, 2023 06:23:10
[Internet connected] IP address: 192.168.100.10, Friday, August 18, 2023 06:22:54
[Internet connected] IP address: 192.168.100.10, Friday, August 18, 2023 06:22:38
[DHCP IP: 192.168.1.11][Device Name: ZENFONE-9] to MAC address 06:0a:1f:a0:bf:70, Friday, August 18, 2023 06:22:24
[Internet connected] IP address: 192.168.100.10, Friday, August 18, 2023 06:22:22
[Internet connected] IP address: 192.168.100.10, Friday, August 18, 2023 06:22:06
[Internet connected] IP address: 192.168.100.10, Friday, August 18, 2023 06:21:51
[Internet connected] IP address: 192.168.100.10, Friday, August 18, 2023 06:21:35
[Internet connected] IP address: 192.168.100.10, Friday, August 18, 2023 06:21:18
[DHCP IP: 192.168.1.10][Device Name: PETKIT_DFOOD] to MAC address c4:5b:be:c7:16:e5, Friday, August 18, 2023 06:18:05
- plemansAug 24, 2023Guru - Experienced UserWe need the event logs and cable connection page. Not the standard logs
