vinnyd51
Jan 22, 2021Tutor
Upstream LED flashes continuously
I saw the answer to this question, but I'm still confused. When I first purchased this modem router a few weeks ago, the upstream LED flashed continuously. A couple of days later it was solid green. ...
Jan 23, 2021Guru - Experienced User
It usually means only 1 upstream channel is locked.
do you have a screen snip of your cable connections page and the logs from the modem? That lets us check the signal.
If you do have any splitters, attenuators, or amplifiers, remove them from the coax line. Check the line for damage, kinks, loose/old/bad connections.
