007goldeneye
May 18, 2020Follower
Upstream light consist flashing
Hello, I've had issues regarding slow connection speeds since the end of March. I've noticed the upstream light on the modem is flashing consistly, when I do a power cycle is stays solid for more tha...
May 19, 2020Guru - Experienced User
Yes, take a screen snip of the cable connection page with upstream/downstream info. get all the info from the page.
Also get a screen snip of the logs.
If you have any splitters, attenuators, or amplifiers in line, I'd remove them as well. They can cause issues.
