luvgolf
Jul 19, 2020Follower
upstream light is constantly red. does anyone know why?
Jul 20, 2020Guru - Experienced User
Agree with FURRYe38 . on what device?
If there's any splitters, amplifiers, or attenuators in line, remove them. Also, check the coax cable for corrosion, kinks, loose/cheap ends, and make sure there's no damage to it.
vkdelta
Jul 21, 2020NETGEAR Employee Retired
Most likely he is talking about CM500 or other modems.
if there is no US bonding, US LED is AMBER.
If the US is in partial service or MSO does not support bonding, then US LED will be AMBER on CM500.
