brmoore9
Aug 18, 2023Aspirant
Upstream Light on CM2000 Blinks Constantly
Just installed new CM2000 to replace an old CM1000. The installation through Xfinity went smoothly except for the fact that the Upstream light is constantly blinking. The old CM1000 never did this. T...
- Aug 26, 2023
Just to let everyone know Xfinity tech came to house today and determined that the outside cable (been in the ground for 18 years) was damaged and replaced the cable. This resolved the issue as internet now works properly.
Aug 18, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the brand and model of the host wifi router connected to the modem
brmoore9
I also noticed that I now get a send/receive error in my Outlook email although the mail comes through and Outlook shows as being connected.
