brmoore9
Aug 18, 2023Aspirant
Upstream Light on CM2000 Blinks Constantly
Just installed new CM2000 to replace an old CM1000. The installation through Xfinity went smoothly except for the fact that the Upstream light is constantly blinking. The old CM1000 never did this. T...
- Aug 26, 2023
Just to let everyone know Xfinity tech came to house today and determined that the outside cable (been in the ground for 18 years) was damaged and replaced the cable. This resolved the issue as internet now works properly.
Aug 18, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
brmoore9
| Frequency Start Value | ||||||||||
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | ||||||||||
Startup Procedure
| Procedure | Status | Comment |
| Acquire Downstream Channel | 621000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enabled | BPI+ |
| IP Provisioning Mode | Honor MDD | IPv6 only |
Downstream Bonded Channels
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables |
| 1 | Locked | QAM256 | 21 | 621000000 Hz | -1.3 dBmV | 41.2 dB | 0 | 0 |
| 2 | Locked | QAM256 | 6 | 531000000 Hz | -0.6 dBmV | 41.8 dB | 0 | 0 |
| 3 | Locked | QAM256 | 7 | 537000000 Hz | -0.7 dBmV | 41.7 dB | 0 | 0 |
| 4 | Locked | QAM256 | 8 | 543000000 Hz | -0.5 dBmV | 41.8 dB | 0 | 0 |
| 5 | Locked | QAM256 | 9 | 549000000 Hz | -0.5 dBmV | 41.7 dB | 0 | 0 |
| 6 | Locked | QAM256 | 10 | 555000000 Hz | -0.8 dBmV | 41.6 dB | 0 | 0 |
| 7 | Locked | QAM256 | 11 | 561000000 Hz | -0.9 dBmV | 41.5 dB | 0 | 0 |
| 8 | Locked | QAM256 | 12 | 567000000 Hz | -1.1 dBmV | 41.5 dB | 0 | 0 |
| 9 | Locked | QAM256 | 13 | 573000000 Hz | -1.0 dBmV | 41.5 dB | 0 | 0 |
| 10 | Locked | QAM256 | 14 | 579000000 Hz | -0.9 dBmV | 41.5 dB | 0 | 0 |
| 11 | Locked | QAM256 | 15 | 585000000 Hz | -1.0 dBmV | 41.4 dB | 0 | 0 |
| 12 | Locked | QAM256 | 16 | 591000000 Hz | -1.1 dBmV | 41.3 dB | 0 | 0 |
| 13 | Locked | QAM256 | 17 | 597000000 Hz | -1.1 dBmV | 41.4 dB | 0 | 0 |
| 14 | Locked | QAM256 | 18 | 603000000 Hz | -1.0 dBmV | 41.5 dB | 0 | 0 |
| 15 | Locked | QAM256 | 19 | 609000000 Hz | -0.9 dBmV | 41.6 dB | 0 | 0 |
| 16 | Locked | QAM256 | 20 | 615000000 Hz | -1.1 dBmV | 41.3 dB | 0 | 0 |
| 17 | Locked | QAM256 | 22 | 627000000 Hz | -1.6 dBmV | 40.9 dB | 0 | 0 |
| 18 | Locked | QAM256 | 23 | 633000000 Hz | -1.8 dBmV | 40.8 dB | 0 | 0 |
| 19 | Locked | QAM256 | 24 | 639000000 Hz | -1.9 dBmV | 40.8 dB | 0 | 0 |
| 20 | Locked | QAM256 | 25 | 645000000 Hz | -1.8 dBmV | 40.8 dB | 0 | 0 |
| 21 | Locked | QAM256 | 26 | 651000000 Hz | -1.7 dBmV | 40.9 dB | 0 | 0 |
| 22 | Locked | QAM256 | 27 | 657000000 Hz | -1.9 dBmV | 40.8 dB | 0 | 0 |
| 23 | Locked | QAM256 | 28 | 663000000 Hz | -2.3 dBmV | 40.4 dB | 0 | 0 |
| 24 | Locked | QAM256 | 29 | 669000000 Hz | -2.4 dBmV | 40.3 dB | 0 | 0 |
| 25 | Locked | QAM256 | 30 | 675000000 Hz | -2.2 dBmV | 39.3 dB | 0 | 0 |
| 26 | Locked | QAM256 | 31 | 681000000 Hz | -2.0 dBmV | 40.7 dB | 0 | 0 |
| 27 | Locked | QAM256 | 33 | 687000000 Hz | -1.7 dBmV | 40.8 dB | 0 | 0 |
| 28 | Locked | QAM256 | 34 | 693000000 Hz | -2.0 dBmV | 40.6 dB | 0 | 0 |
| 29 | Locked | QAM256 | 35 | 699000000 Hz | -2.2 dBmV | 40.3 dB | 0 | 0 |
| 30 | Locked | QAM256 | 36 | 705000000 Hz | -2.5 dBmV | 40.2 dB | 0 | 0 |
| 31 | Locked | QAM256 | 37 | 711000000 Hz | -2.3 dBmV | 40.2 dB | 0 | 0 |
| 32 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
Upstream Bonded Channels (Partial Service)
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
| 1 | Locked | ATDMA | 1 | 5120 Ksym/sec | 35600000 Hz | 58.0 dBmV |
| 2 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV |
| 3 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV |
| 4 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV |
| 5 | Locked | ATDMA | 5 | 2560 Ksym/sec | 40400000 Hz | 55.5 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV |
Downstream OFDM Channels
| Channel | Lock Status | Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | 0 ,1 ,2 ,3 | 32 | 762000000 Hz | -1.72 dBmV | 39.8 dB | 1108 ~ 2987 | 10275805 | 10078087 | 0 |
| 2 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV | 0 dB | 0 ~ 4095 | 0 | 0 | 0 |
Upstream OFDMA Channels
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power |
| 1 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV |
Extended Upstream Transmit PowerEnable Extended Upstream Transmit Power
Current System Time:Fri Aug 18 13:19:31 2023System Up Time:00:15:54
- FURRYe38Aug 18, 2023Guru - Experienced User
Well power levels are with in spec:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
No correctables or un-correctables which is good.
Status shows poor though...Lets see the Events log please.
- brmoore9Aug 20, 2023Aspirant
Sorry it took so long to reply back. Here is the most recent event log.
Clear Log Refresh Export Time Priority Description Sun Aug 20 13:58:57 2023 (Critical (3)) No Ranging Response received - T3 time-out;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:58:47 2023 (Critical (3)) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:58:47 2023 (Critical (3)) Ranging Request Retries exhausted;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:58:47 2023 (Critical (3)) No Ranging Response received - T3 time-out;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:58:08 2023 (Critical (3)) 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:58:08 2023 (Critical (3)) Ranging Request Retries exhausted;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:58:08 2023 (Critical (3)) No Ranging Response received - T3 time-out;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:55:52 2023 (Critical (3)) 16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:55:52 2023 (Critical (3)) Ranging Request Retries exhausted;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:55:52 2023 (Critical (3)) No Ranging Response received - T3 time-out;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:54:34 2023 (Critical (3)) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:54:34 2023 (Critical (3)) Ranging Request Retries exhausted;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:54:34 2023 (Critical (3)) No Ranging Response received - T3 time-out;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:51:14 2023 (Critical (3)) 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:51:14 2023 (Critical (3)) Ranging Request Retries exhausted;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:51:14 2023 (Critical (3)) No Ranging Response received - T3 time-out;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:49:43 2023 (Critical (3)) 16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:49:43 2023 (Critical (3)) Ranging Request Retries exhausted;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:49:43 2023 (Critical (3)) No Ranging Response received - T3 time-out;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:49:05 2023 (Critical (3)) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:49:05 2023 (Critical (3)) Ranging Request Retries exhausted;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:49:05 2023 (Critical (3)) No Ranging Response received - T3 time-out;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:45:40 2023 (Critical (3)) 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:45:40 2023 (Critical (3)) Ranging Request Retries exhausted;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:45:40 2023 (Critical (3)) No Ranging Response received - T3 time-out;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:42:58 2023 (Critical (3)) 16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:42:58 2023 (Critical (3)) Ranging Request Retries exhausted;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:42:58 2023 (Critical (3)) No Ranging Response received - T3 time-out;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:42:40 2023 (Critical (3)) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:42:40 2023 (Critical (3)) Ranging Request Retries exhausted;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:42:40 2023 (Critical (3)) No Ranging Response received - T3 time-out;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:40:38 2023 (Critical (3)) 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:40:38 2023 (Critical (3)) Ranging Request Retries exhausted;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:40:38 2023 (Critical (3)) No Ranging Response received - T3 time-out;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:37:10 2023 (Critical (3)) 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:37:10 2023 (Critical (3)) Ranging Request Retries exhausted;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:37:10 2023 (Critical (3)) No Ranging Response received - T3 time-out;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:36:36 2023 (Critical (3)) 16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:36:36 2023 (Critical (3)) Ranging Request Retries exhausted;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; Sun Aug 20 13:36:36 2023 (Critical (3)) No Ranging Response received - T3 time-out;CM-MAC=94:18:65:2c:16:13;CMTS-MAC=00:01:5c:70:14:a2;CM-QOS=1.1;CM-VER=3.1; - FURRYe38Aug 21, 2023Guru - Experienced User
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
