russjobes's avatar
russjobes
Follower
Aug 14, 2022
Upstream red light
AC1900v2
1 Reply
  • plemans's avatar
    What unit do you have? AC1900 is a speed.
    usually if the upstream is red, its either trying to lock a channel or can't find one.
    Start with removing any amplifiers, signal attenuators, or splitters from the coax.
    From there check the line for kinks, damage, moisture in the line.
    Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
    If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
