Knatt94
Sep 26, 2020Follower
USB antenna
Do they have usb antenna to increase the range of my WiFi? If so which are the best recommendations?
- Sep 26, 2020
No. I would recommend getting into a wifi mesh system, like a NGs Nighthawk mesh system or Orbi mesh. There is a Orbi 1 series that you could connect up to your modem.
Sep 26, 2020Guru - Experienced User
