Walt-1
Dec 22, 2021Tutor
usb fax modem
Is there a usb fax modem, plugged int my laptop, that works with the CM1150V?
- Dec 23, 2021
This whole thing didn't make sense.
Are you wanting the fax modem plugged into your laptop or plugged into the cm1150v?
What are you actually trying to do?
The CM1150V (if you have voice through your ISP), can handle fax modems.
Dec 23, 2021Guru - Experienced User
- Walt-1Dec 31, 2021Tutor
Thanks plemans,
I finally added a 2-line splitter to the phone input on the CM1150V and plugged in my Zoom 56K USB Modem. Used Windows Fax and Scan and it worked like a charm. Thanks for your response, Walt
