MLB7061
Mar 11, 2021Aspirant
USB HD connected to C7000v2
Is there any way to optomize a USB Hard Drive attached to my C700v2? I have a 2TB unit that use as backup to two PCs. thanks for any info.
Mar 11, 2021Guru - Experienced User
Not sure what exactly you're expecting by "optimizing" it.
What's your goal or what are you attempting/expecting?
MLB7061
I use the drive with two computers one with Windows 10 Pro 64 Bit and one with two operating systems, Windows 10 Pro 32 bit and one with Ubuntu 20.04. since this drive is the only drive accessable by all systems I use it for some information storage other than backup (music, pictures, help files, etc.). I have found over the years that defraging a hard drive (at least for windows OS s) is advantageous. Thank you for your response.
- plemansMar 11, 2021Guru - Experienced User
You could always connect it to a windows pc and defrag it.
But on newer drives, usually the bottleneck isn't the external hard drive. Its usually the usb 2.0 interface that slows things down.
That's why you see people migrating to NAS's
