morganjeff7272
Jul 30, 2016Follower
usb mapping utility readyshareconnect.exe for windows ten manual is incorrect.
I got hung up on by netgear support. I called them to locate the file readyshareconnect.exe that is supposed to be locatated at www.netgear.com/readyshare I also would like to veiw compatable HDD l...
TheEther
Jul 31, 2016Guru
Google is your friend.
I searched for readyshareconnect.exe and the first link leads to a page where you can download the program (link).
I searched for readyshare compatible hdd and once again the first link was on the money (link). Your Seagate is not listed but there should be no reason why it wouldn't work.
Search for window map network drive for instructions for permanently mapping the drive.
