ZeroGee
Mar 12, 2022Aspirant
USB Storage not found on C3000-100NAS
Firmware version: V2.02.21 Model: C3000-100NAS Mfg Label: Netgear Operating System: Windows 10 Pro w/ latest patches 1. Admin home page shows ReadySHAR...
- Mar 13, 2022
Found the issue: the Network Neighborhood option was not enabled so the readyshare server was not responding to mapping requests.
michaelkenward
Mar 13, 2022Guru - Experienced User
Do you have any other USB drives you could try?
ReadySHARE can be picky.
The list of known devices for this modem/router is no encouraging:
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
But it is usually on the pessimistic side and out of date.
What do you see here?
ADVANCED > USB Storage > Advanced Settings
- ZeroGeeMar 13, 2022Aspirant
I have removed the WD My Cloud Mirror and replaced it with a Toshiba portable 500GB drive. I had the same results when I tried to map a network drive to either of the 2 PCs on the local area network. I have attached the screen shot as requested. The error message seems to indicate that \\readyshare is not a broadcast servername, so I tried \\192.168.0.1 and received the same results. I have the gateway set NOT to broadcast the Network ID, but seriously doubt that is the issue.
- michaelkenwardMar 13, 2022Guru - Experienced User
Windows strikes again.
The picture seems to show that you have a couple of drives connected to ReadySHARE.
You haven't shown the complete error message, but from the screenshot you should get into the "Toshiba USB Portable" with:
What happened when you plugged in the WD My Cloud Mirror?
Where does BACKUP_BOOT come from?
Can you access?
\\readyshare\USB_Storage
I had the same results when I tried to map a network drive to either of the 2 PCs on the local area network.Not sure what you are doing to "map" these drives. Are trying to Edit Network Folder?
That doesn't seem to work unless you can get at them with \\readyshare\
