shumm
Sep 15, 2016Aspirant
Use my N600 WiFi Cable Modem Router as an extender?
I'm moving into a new place and the main house has a wifi router already there set up. I'd like to use my N600 as an access point in the cottage behind the house. Can I wirelessly connect my N600 to ...
shumm
Hi. I don't have the router with me at the moment, but Amazon tells me it is a C3700 model.
What does "no to your question." mean? I can't use it as an extender?
Anonymous
Sep 15, 2016Yes,
Use the dowload tab above and locate the manual for any netgear product you're considering. If you need a extender then purchase one.
Why would you even consider a cable modem router to be used as a extender?
- shummSep 15, 2016Aspirant
I downloaded the manual but it doesn't have any info on turning it into an extender.
Ordinarily I wouldn't buy a router to use as an extender, but as I mentioned in my initial post I just happen to have this router as an extra piece of equipment and would rather not have to buy another piece of equipment if I don't need to. The house I'm moving into already has a wifi router set up, but it doesn't have enough range on its own. This C3700 router seems like it is sophisticated enough to be able to do that, but there isn't any documentation about it.
- AnonymousSep 15, 2016
If the manual doesn't list it then it's safe to assume it doesn't have that option.
"This C3700 router seems like it is sophisticated enough to be able to do that, but there isn't any documentation about it".
http://www.downloads.netgear.com/files/GDC/C3700/C3700_UM_21Aug2014.pdf
It's a cable modem router combo and it is sophisticated in that is has a router and modem together in one box. But that in no way is what you need.
You cannot assume anything regarding this stuff anymore. Yes some time ago many had a repeater or extender option BUT that option had little to no security, it's been dropped. EXTENDERS made to extend have replaced it.
