DKRacingFan
Jun 18, 2019Aspirant
Use Netgear C3700 N600 as Modem Only
Hello! I am planning to upgrade to a different wifi router in the future. Can I use this modem/router as a modem only and connect a router to it? Thanks! I heard that the C3700/N300 doesen't, but i...
- Jun 18, 2019
When the C3700 is fully bridged, then the R6700 router will work with it.
Jun 18, 2019Guru - Experienced User
I would review the user manual to see if there is any bridge mode or modem mode or disable NAT mode features for this modem combo. Most modem combo supports modem only mode.
