DKRacingFan
Jun 18, 2019Aspirant
Use Netgear C3700 N600 as Modem Only
Hello! I am planning to upgrade to a different wifi router in the future. Can I use this modem/router as a modem only and connect a router to it? Thanks! I heard that the C3700/N300 doesen't, but i...
- Jun 18, 2019
When the C3700 is fully bridged, then the R6700 router will work with it.
antinode
Jun 18, 2019Guru
> [...] C3700 [...]
C3700 or C3700v2? Look at the product label.
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Look for "Cable Your
Modem Router to a Router or Gateway".
> I heard that the C3700/N300 doesen't, but i'm wondering if the
> C3700/N600 does.
I don't know what you heard where, but I don't see any "C3700/N300"
at "http://netgear.com/support".
